I need to get my front tire replaced and I was quoted a price of 52.00 if they remove the wheel and 26.00 if bring the wheel in only. I've searched the forums and found a couple hits on removing the wheel but I'm still not sure what the proper procedure is.
When I remove the brake calipers do I just remove the 2 hex bolts located on the top caliper and let them hang down? Also, I believe axel is threaded so which side do I loosen the hex bolts and then the axel? Any help is greatly appreciated.
